Home » Audio » Speaker » sensitivity question
Re: sensitivity question [message #16332 is a reply to message #16325] Fri, 09 April 2004 15:19 Go to previous messageGo to previous message
With the Klipsch, I do need to cut back the range around 60Hz to make flat response, but still the entire range below that needs more gain with the EV's then the Klipsch at the same volume control setting. The entire bass range below 60Hz needs to be boosted several dB for the EV's. When using the EV's, I boost the 62Hz eq on my graphic eq used with the sub. That's the only eq change from one speaker to the next.
The graphic eq is only used with the sub amp, and is set for flat response with each speaker system used.
Dave
Previous Topic: More spectacular Horns
Next Topic: Opinions - Eminence Deltalite 10 and 12
Current Time: Tue Nov 03 07:40:06 CST 2026
