Home » Audio » Speaker » The Tuba 24 Compact Folded Horn Sub.
Re: The Tuba 24 Compact Folded Horn Sub. [message #16252 is a reply to message #16251] Sun, 28 March 2004 06:27 Go to previous message
The horn Fc is around 60 Hz in half-space, below that radiation is primarily direct-radiator mode, though when boundary assisted in room the effective path length and mouth area is increased. The design is specifically intended for live pro-sound, where boundaries aren't usually present; within the horn passband boundary loading has little effect. On the other hand, since room loading will bring response below 60 Hz up to a reasonable level, the design is also viable for hi-fi/HT, though less than ideal. It's not a Labhorn, but at 24" cubed it was never intended to be.
Previous Topic: fostex 206's
Next Topic: listening to 206's
Current Time: Tue Nov 03 10:58:37 CST 2026
