Home » Audio » Speaker » basshorns ctd
basshorns ctd [message #16220] Sat, 13 March 2004 10:53 Go to next message
So some people have already used a basshorn in a car ;-)
but did they hornresp it! no sealed rear chamber,so horn must be a little longer for same low freqs.
"149.6db DEATHMATCH Score, Average over 5 minutes!!!!
Re: basshorns ctd [message #16221 is a reply to message #16220] Sat, 13 March 2004 11:44 Go to previous messageGo to next message
You might also check out Eminence's new HL-10 subwoofer. It's smaller, so it might be really great for your car subwoofer application.
MASSIVE HORNSUB [message #16234 is a reply to message #16221] Mon, 15 March 2004 12:24 Go to previous messageGo to next message
DanR is currently offline  DanR
Wayne, Mike, please see my hornsub note in the prospeakers section.
I think the labhorn is pretty impressive already [message #16235 is a reply to message #16234] Mon, 15 March 2004 18:00 Go to previous message
So you want 20hz for a PRO unit event/ you wont get high efficiency from a DOORway movable horn.
perhaps 100db/1watt only ...
Id use the lab12 because its such high xmax,with LF youd need the excursion.
The question is,do you need it,really i think a labhorn or similar will suit the task just as well. 30hz clean is very impressive on its own
Cheers!
Previous Topic: Amps for Maggies
Next Topic: Hospital 2Pi's
Current Time: Wed Nov 04 15:06:36 CST 2026
