Home » Audio » Speaker » Cone vs Compression in Midrange
Cone vs Compression in Midrange [message #16215] Fri, 12 March 2004 09:16 Go to previous message
Interested in knowing the difference between using a compression horn vs. cone driver horn for the midrange. I know the bandwidth of the two are different. A 2" compression will give you 500Hz (if you're lucky) to 10 or 15KHz, while a midrange cone can run from 100Hz to 5KHz. But within that area of overlap, what are the major differences in tonal characteristics?
Gar.
Previous Topic: A few questions
Next Topic: Altec or bust
Current Time: Fri Oct 16 19:17:49 CDT 2026
