Home » Audio » Speaker » Another Hornresp Question
Re: Another Hornresp Question [message #16155 is a reply to message #16154] Fri, 20 February 2004 23:39 Go to previous messageGo to previous message
Are you modeling in eighth-space (π/2) perhaps? If so, you might want to model in half-space (2π) instead. That is the way it will be if the horn is baffle mounted. If it won't be mounted on a baffle, then modeling in free-space (4π) might be more appropriate.
You set this value in the ANG field. If it is set for 0, you're modeling an infinite horn which always has a nice response curve. Generally, use in larger areas makes response more peaky. So worst-case is usually freespace response.
Previous Topic: Hey Wayne!
Next Topic: Definition of Frequency Ranges
Current Time: Tue Nov 03 15:00:47 CST 2026
