Home » Audio » Speaker » Questions about piezo super tweet
Re: Questions about piezo super tweet [message #16120 is a reply to message #16119] Mon, 09 February 2004 14:19 Go to previous message
Transformer coupling was a standard practice on the early units. It is still done by some, but be careful not to push the voltage increase too far. High turns ratios - above about 6dB gain - will increase distortion.
I use piezo tweeters on the smaller entry level speakers that are only about 96dB/M/W. So I don't need to increase their sensitivity. But if I were to consider the use of transformers, I would not go much past about 100dB/W/M. If higher output is needed, I'd go with a different tweeter than the KSN1038 or similar units.
Previous Topic: 30hz horn design complete.
Next Topic: Adjusting for difference in gain in biamping
Current Time: Fri Nov 06 01:23:41 CST 2026
