Home » Audio » Speaker » Questions about piezo super tweet
Re: Questions about piezo super tweet [message #16115 is a reply to message #16113] Sun, 08 February 2004 16:29 Go to previous messageGo to previous message
If you put an 8-20 ohm resistor across the tweeter, that becomes the most significant load. So you can then treat it like a purely resistive device. For example, if you use an 8 ohm resistor across the tweeter, then a 3.3uF series capacitor will make a first-order crossover set for 6kHz. These values become what you would expect for an 8 ohm speaker. You can also do the same kind of thing with a 16 ohm resistor if you need a 16 ohm load.
So pick the resistor you need for the load you want and design your crossover accordingly. The tweeter circuit will actually have a very smooth impedance curve - Better than a voice coil speaker and a Zobel.
Previous Topic: 30hz horn design complete.
Next Topic: Adjusting for difference in gain in biamping
Current Time: Fri Nov 06 01:23:09 CST 2026
