Home » Audio » Speaker » New! Improved???
Re: Tweeter - Thank you, Wayne [message #15999 is a reply to message #15986] Tue, 06 January 2004 15:22 Go to previous messageGo to next message
Looks very good, you said:
"The reflex driver is XO at 175 Hz to the mid-horn. Again the integration with the whole seems pretty good, but not as good as with the mid and top horns."
I don't know if you can do it on your x-over or not, but try delaying the reflex-driver to match the depth of the mid/hi horns and see what happens. If not you may have to play around with x-over freq. between the reflex and the mid-horn.
HTH
Bill W.
Good thought, Bill [message #16000 is a reply to message #15999] Wed, 07 January 2004 00:36 Go to previous message
Wavelength at the 175Hz crossover frequency is 6.5 feet. That gives a window of about a foot and a half to two feet to stay within 90o to 120o. The crossover will also introduce phase, but the point is that we're talking about critical distances of about a foot or two. If the depth is a foot, I'm pretty sure Charlie would find he's within a quarter-wavelenth or 90o. If the distance is greater, then there may be reason to do some measurements and/or calculations to find out if the phase difference exceeds 120o. That represents a third-wavelenth, where we start seeing the edge of nulls begin to develop.
Previous Topic: vintage 8" fullrange speakers
Next Topic: Single driver speaker suggestion
Current Time: Mon Nov 09 06:28:13 CST 2026
