Home » Audio » Speaker » New! Improved???
New! Improved??? [message #15977] Thu, 01 January 2004 19:16 Go to previous message
A short report on a speaker modification.
Over the pat week I finished modifying my home-built Altec A7s. Based on discussions by Roland R on other boards, I enclosed the woofer/mid-horn driver (515-G) isolating it from the reflex space, leaving a back chamber of approximately 42 liters. The chamber is lined with acoustic (egg crate) foam. I'm running Altec 802s on 511 horns on top.
The reflex chamber, approximately 5-1/2 cubic feet, is dual-ported in the rear, 4-1/8" Dia X 3-3/4" long (40 Hz). The front baffles are two layers of 3/4" plywood (1-1/2" total). The drivers in the reflex chamber are JBL 2225.
The things are driven through a Rane MX-23 with Crown D-75As on top and a Crown Com Tech 200 on the bottom.
The "mid-horn" seems to integrate really well with the 511/802 combination at about 600 Hz. It's surprisingly seamless, even at a few feet away - you don't have the impression that either source is dominant on solo female voice, which I think is pretty good.
The reflex driver is XO at 175 Hz to the mid-horn. Again the integration with the whole seems pretty good, but not as good as with the mid and top horns.
Still fooling with level matching. I haven't done any measurements, principally because I don't know what to do. I have an SPL meter and I may do some investigations with it after some reflection.
Right now I think it's a vast improvement over the stock A7 in that the totally absent bottom is overcome in a pretty musical way. Having braced, damped and altered these cabinets to high heaven, I think this will be the end of the road for this approach. The next time out will be a fresh start with a different configuration altogether.
Previous Topic: vintage 8" fullrange speakers
Next Topic: Single driver speaker suggestion
Current Time: Tue Nov 03 09:40:18 CST 2026
