Home » Audio » Speaker » Coral speakers
Re: Coral speakers [message #15720 is a reply to message #15663] Mon, 29 September 2008 12:22 Go to previous message
RAW is currently offline  RAW
Here is a set for you if I was close grab them for $175.00 just for parts
http://chicago.craigslist.org/sox/ele/857659206.html
On the crossovers yes replacing the capacitors as well the parts layout can be a issue as well with having cross talk on some inductors.
With the capacitors I would lean to Mundorf caps and possible bypass capacitors, change out the resistors as well these will need replacement also.Inductors may have come un wound yes i have seen older inductors come apart as well. The trick with replacing the inductors if needed is to make sure you use a inductor with the same DCR.
Here is a photo of few Corel I just did.
Previous Topic: PHY HP21 vs. Accuton T6-96
Next Topic: Help! Speaker Interference
Current Time: Wed Oct 21 04:48:44 CDT 2026
