Home » Audio » Speaker » Electro-voice 30 inch woofer
Re: Electro-voice 30 inch woofer [message #15692 is a reply to message #15689] Sat, 05 July 2008 11:10 Go to previous messageGo to previous message
DanR is currently offline  DanR
Bill and Wayne - thank you for the information about the EV 30 inch woofer, the Fostex speaker, the Opal system, and the DIY project. Most interesting.
An academic question: Is the need for high power and/or a huge speaker in order to "move air" so that low frequencies can be heard caused by the need to compensate for the ears' inadequate air conduction to the ear-drum?
The Fletcher-Munson effect?
Another memory check:
Do you recall, from the early 60's, a project in one of the electronic hobbyist magazines called "The Sweet Sixteen"?
Sixteen run-of-the-mill small diameter speakers were mounted in a single large enclosure. The thought was that together they could move a lot of air with little distortion because the cone movement of each speaker was reduced. My neighbor at the time built one and I remember that it sounded really good.
Previous Topic: which speaker to use ?
Next Topic: dummy impedance/power load to replace speaker being repaired?
Current Time: Sun Nov 08 23:54:49 CST 2026
