Home » Audio » Speaker » Coral speakers
Re: Coral speakers [message #15664 is a reply to message #15663] Fri, 18 April 2008 10:32 Go to previous messageGo to previous message
I suggest replacing the capacitors with new polypropylene caps. If you can solder, you can do it yourself. If not, yake your speakers to a repair shop. Pick the capacitors yourself and take them with you though because very few repair shops will have the parts you want in stock. They may be tempted to replace the caps with non-polarized electrolytics, which aren't very good. It's better to use polypropylene capacitors.
Previous Topic: PHY HP21 vs. Accuton T6-96
Next Topic: Help! Speaker Interference
Current Time: Wed Oct 21 04:45:49 CDT 2026
