Home » Audio » Speaker » What will dampen the sound on in-wall speakers?
Re: What will dampen the sound on in-wall speakers? [message #15547 is a reply to message #15464] Fri, 03 August 2007 23:41 Go to previous message
granch is currently offline  granch
If you were free to use different speakers, I would highly recommend the Altec/Western Electric 755 or 755A. These are designed for a box little bigger than the speaker itself and should fit easily, with box, in your walls. They will give you everything but deep bass which you should get from a larger subwoofer anyhow. Boxed or not I guarantee you will like the sound. What does my guarantee mean? It means that I will gladly take them off your hands at a price I can afford....which, to be honest is not much. The 755 is the speaker that, along with its air-spring bass woofer, revolutionized audio in the mid '50's in the AR -1 bookshelf speaker system.
Dick
Previous Topic: subwoofer project suggestions
Next Topic: GR Research
Current Time: Fri Oct 23 12:50:17 CDT 2026
