Home » Audio » Speaker » JBL G-730 Diaphragm quest
JBL G-730 Diaphragm quest [message #15539] Tue, 24 July 2007 12:32 Go to next message
xnay is currently offline  xnay
What does a bad mid-range driver diaphragm sound like?? Is there hissing, cracking, buzzing, etc.?? It seems the voice just doesn't seem as clear as it should, like it's drowning. Was hoping to get a little feedback before investing $$$ for new ones. Thanks in advance
Re: JBL G-730 Diaphragm quest [message #15540 is a reply to message #15539] Wed, 25 July 2007 09:48 Go to previous messageGo to next message
One of the most common symptoms of a blown driver is buzzing. This happens when the voice coil begins to unwind from heat weakening the adhesive that holds it to the former. It then rubs on the pole piece. This can make it buzz or sound fuzzy or scratchy. Another thing that can happen is a tear of the surround or damage to the diaphragm itself. This is usually caused by overexcursion or contact with the phase plug (in a compression driver) or foreign debris. This will usually sound lower in volume and different in tonal character, sometimes buzzing as well.
Re: JBL G-730 Diaphragm quest [message #15541 is a reply to message #15540] Fri, 27 July 2007 11:40 Go to previous message
Thank you Wayne, for elaborating in such detail. Your reply is very clear and informative. I learned much.
Robert
Previous Topic: DCX crossover installed
Next Topic: Conical HF Horn?
Current Time: Sun Nov 08 22:05:38 CST 2026
