Home » Audio » Speaker » electro-voice sp-15
electro-voice sp-15 [message #15484] Wed, 04 April 2007 19:03 Go to next message
david is currently offline  david
Purchase some speakers at the bargan shop, opened them and they have electro-voice sp-15's. Have no knowledge of these speakers. Can anyone help. Thanks David
Re: electro-voice sp-15 [message #15499 is a reply to message #15484] Wed, 25 April 2007 14:34 Go to previous messageGo to next message
tomt is currently offline  tomt
what would you like to know?
Re: electro-voice sp-15 [message #15502 is a reply to message #15499] Fri, 27 April 2007 11:04 Go to previous messageGo to next message
I noticed the speakers have 16 ohms stamped on the back; is it OK to use these with a typical home receiver at 8 ohms? Have no idea regarding the sound quality or handing capabilities. The cabinet's appear old are these speakers somewhat dated? As you can tell I really don't have a clue about these speakers other than they are heavy. Thank you in Advance, David
Re: electro-voice sp-15 [message #15504 is a reply to message #15502] Sat, 05 May 2007 11:48 Go to previous messageGo to next message
i'd say you done good
typical home reciever, will usually note on back the 'ohm rating'
i have the 'sp-12', that i'm rather fond of-
i'm shure you'll like these.
Re: electro-voice sp-15 [message #15509 is a reply to message #15504] Thu, 10 May 2007 18:23 Go to previous messageGo to next message
sp-12
Re: electro-voice sp-15 [message #15543 is a reply to message #15502] Mon, 30 July 2007 22:33 Go to previous messageGo to next message
granch is currently offline  granch
The SP-12 was the big brother (beefier) of the SP-12B. The SP-12B was a phenomenal speaker for its day (around 1950) and that means it will still sound good. I used mine in a copy of an Electrovoice corner horn cabinet that I built in College. It sounded just great! I later added a Karkson cabinet and the combination of the two stacked was phenomenal. This was before stereo.
-Dick
Re: electro-voice sp-15 [message #15544 is a reply to message #15543] Tue, 31 July 2007 07:06 Go to previous messageGo to next message
Thank You.
I would like to look into the possibilities of allowing these speakers a chance to be used as intented. If
anyone can help I would enjoy the help.Thank you for you help. I'll post some additional photo's. David
Re: electro-voice sp-15 [message #15545 is a reply to message #15544] Tue, 31 July 2007 13:32 Go to previous message
I would expect the SP-15 to be a still bigger brother to the SP-12B that I used. Thus similar midrange and highs, but more and deeper base. I would guess that a rear loaded corner horn such as I used would be geat allowing the front to radiate into the roomand the back be horn loaded. Many other possibilities exist. Even a Karlson might work very well. Good luck.
Dick
Previous Topic: Solid wood Pawos
Next Topic: subwoofer project suggestions
Current Time: Thu Oct 15 21:17:08 CDT 2026
