Home » Audio » Speaker » possible blown woofer? help?
Re: possible blown woofer? help? [message #15480 is a reply to message #15477] Wed, 21 March 2007 09:24 Go to previous messageGo to previous message
That's a pretty common symptom of a blown speaker. What happens is that heat in the voice coil causes the glue to fail and the voice coil unwinds. The most common symptoms are rubbing, grinding or buzzing sounds, reduced output and tonal shift.
Previous Topic: another ART array question....
Next Topic: Use of multi-meter for measure impedance of lines Question..
Current Time: Sun Nov 01 07:18:26 CST 2026
