Home » Audio » Speaker » possible blown woofer? help?
possible blown woofer? help? [message #15477] Tue, 20 March 2007 22:51 Go to previous message
Tony K is currently offline  Tony K
Is it possible for a woofer to blow, but still leave a tweeter and built-in subwoofer intact? I have a set of NHT SuperTwos, and after a weekend out of town, it appears my housemates had a party and possibly blew my speakers. I personally think the midrange response is not as good as it used to be, while the lows and the highs still sound ok. Looking at the woofer while playing music, I noticed it doesn't visually move as much as it used to. The strange part is though, that if I play a song or something that would primarily come out of the midrange, and turn up the volume (quite a bit more than before), it sounds fine.
It behaves as if the midrange was turned down as if by an equalizer...unfortunately there are no equalizers in play here. Is it possible that something in the reciever (Harmon/Kardon HK3480) broke?
Any help/advice you guys could give would be great. I need to know if I should be getting my housemates to buy me a new set of speakers, or if I am just imagining things.
Previous Topic: another ART array question....
Next Topic: Use of multi-meter for measure impedance of lines Question..
Current Time: Sun Nov 01 04:30:29 CST 2026
