Home » Audio » Speaker » What will dampen the sound on in-wall speakers?
Re: What will dampen the sound on in-wall speakers? [message #15464 is a reply to message #15463] Tue, 20 February 2007 19:06 Go to previous messageGo to previous message
That will help. I thought you had already enclosed the speakers and the problem persisted.
Make the cabinet as large as you reasonably can and fill it with insulation. The speakers are undoubtedly designed for installation on an infinite baffle which means they have relatively high Q. To put them in a small box would caused a large midbass peak and substantially reduce deep bass.
Previous Topic: subwoofer project suggestions
Next Topic: GR Research
Current Time: Sun Sep 13 08:20:41 CDT 2026
