Home » Audio » Speaker » Dynauido crosover design
Dynauido crosover design [message #15410] Fri, 03 November 2006 21:40 Go to next message
Garrett Roach is currently offline  Garrett Roach
I plan on building a two way speaker using dynauido drivers, D28/2 tweeter and 17W75 8 ohm(not the 17W75XL 4 ohm). The enclosure will be sealed with a volume of19 to 28l. Does anyone know where I can get a good crosover design for this configuration. Thanks
Gary
Re: Dynauido crosover design [message #15439 is a reply to message #15410] Tue, 19 December 2006 09:42 Go to previous messageGo to next message
Dr Mark Carter is currently offline  Dr Mark Carter
Dear Garrett,
I did design a cross over for that combination back in 1984, and yes, even back then it was a computer assisted design. My speakers which are still in use, are actually two and a half ways, as they are diffraction compensated. I can easily adapt the design to a straight two way. I used these speakers on location, mainly for outside concert broadcast work. The musicians I worked with always held them in high regard.
If you are interested contact me
Regards, Mark.
Re: Dynauido crosover design [message #15440 is a reply to message #15439] Tue, 19 December 2006 14:53 Go to previous message
Dear Mark
Thanks for your reply. I was able to get the crossover for Madisounds
MDY-4. The MDY-4 used the 17W75EXT and they were kind enough to modify the crossover to acomidate the standard 17W75 driver. I obtained the plans to build the cabinet from a fellow I met from another posting. The MDY-4's are a .5 cuft. enclosure with a Scan Speek Aperiodic vent. I finished them in red oak vineer and Poly high gloss finish. The finished speakers sound excelent.
Previous Topic: Need Help Tuning Vintage Electro Voice Cabinets.
Next Topic: Need help with a center channel
Current Time: Mon Nov 23 10:17:40 CST 2026
