Home » Audio » Speaker » Need help with a center channel
Need help with a center channel [message #15432] Fri, 15 December 2006 16:21 Go to previous message
It has been a very long time since I designed a speaker. I vaguely remember punching the Thiele-Small numbers, one by one into a TI calculator, but it’ all very foggy.
What I want to do, is build a center channel speaker for the home theater setup I am working on. For the mains I am using a pair of Bottlehead Straight 8’s. I have 4, 5" drivers, the MCM 55-1870, the same used in the 8’s. I plan to run 4 or maybe just 2, if it makes more sense, full range. The Fs= 54, Vas 10.04 L, & Qts= .401
The max box size I can use works out be about 1.95 cubic feet. (52.5 Lt.) , a bit smaller would be better but hey, we do what we gotta do…
So, My questions to O yee speaker gurus are.
Can you recommend a simple box program to use, I have not kept up.
How do I model an array as a single driver?
Do you think I should be modeling for a vented or sealed box, I bet if I knew the answer to 1 and 2 I could answer this myself
Thanks in advance…John
Previous Topic: Dynauido crosover design
Next Topic: Zu tone or Druid or which Omega to match 300B?
Current Time: Tue Nov 03 18:37:55 CST 2026
