Home » Audio » Speaker » Finally the x-over is hooked up
Finally the x-over is hooked up [message #15371] Sat, 09 September 2006 21:33 Go to previous message
MWG is currently offline  MWG
I bought a Rane AC-22 pretty cheap so I built some cables for it since it's the older model that uses TS plugs.
I have noticed a couple of things so far. One is I need a setup cd or tone generator for sure The bass seems to be more controlled than before with the tube amp.I'm using a SS MC-2505 for the bottom end and a tube MC-275 for the horns in the Valencias.
I played the Mark Knopfler/Emmy Lou Harris-All the Roadrunning album and it sure sounds sweet. I don't think there is a night and day difference so the old Altec x-over can't be all that bad for as old as it is.
I used the stock split @ 800 HZ. and haven't fooled around with changing it. I think Altec used 800 for a reason so I don't see a big need to fool around with it.
Reading the Rane owners manual is a hoot. They have a sense of humor. Too bad most of the technical stuff is over my head. My peabrain doesn't absorb electronics well I'll figure it out eventually.
Previous Topic: Heavy-cones verses light-cones in basshorns
Next Topic: interesting damping material
Current Time: Fri Nov 06 03:21:32 CST 2026
