Home » Audio » Speaker » Jensen G610
Jensen G610 [message #15229] Sun, 05 March 2006 13:54 Go to next message
David Burch is currently offline  David Burch
I have a Jensen G610 speaker and the paper cone is separated at the center and all around the edge. It’s just sitting there unconnected. Is it possible to have this speaker repaired, and if so are there any recommendations of shops in the San Francisco Bay area.
Any advice is appreciated, Thanks, David
Re: Jensen G610 [message #15230 is a reply to message #15229] Mon, 06 March 2006 14:51 Go to previous messageGo to next message
Try David Miller at Speakerworks, (918) 664-6299. He may be able to help.
Re: Jensen G610 [message #15685 is a reply to message #15229] Fri, 06 June 2008 11:28 Go to previous message
scott brown is currently offline  scott brown
Did you have any luck getting your speakers repaired? I have the exact same problem and can not locate anyone to work on them.
Thank You
Previous Topic: Does you experience apply to horn loading?
Next Topic: Acculab speakers
Current Time: Mon Nov 30 10:52:51 CST 2026
