Home » Audio » Speaker » Vintage speakers vs. modern
Vintage speakers vs. modern [message #15158] Wed, 11 January 2006 04:23 Go to next message
JimBeam is currently offline  JimBeam
Hi there,
I have an opportunity to get a pair of 15" speakers made in 70's. What I wonder about is - do speakers change their quality with the age or not? Can I rely that they'll be up to specs of the time they were made? Thanks for help!
Re: Vintage speakers vs. modern [message #15159 is a reply to message #15158] Wed, 11 January 2006 04:26 Go to previous messageGo to next message
Sorry, forgot to mention - I was talking about a pair of Tannoy Albury SL105
Re: Vintage speakers vs. modern [message #15160 is a reply to message #15159] Wed, 11 January 2006 06:13 Go to previous messageGo to next message
Tannoys always sound good. So; depends on price and what you will be driving them with.
Re: Vintage speakers vs. modern [message #15161 is a reply to message #15160] Wed, 11 January 2006 06:33 Go to previous messageGo to next message
I was planning to put a tube amplifier to run those Tannoys.
Re: Vintage speakers vs. modern [message #15162 is a reply to message #15159] Wed, 11 January 2006 07:39 Go to previous messageGo to next message
I don't know what type of magnet the Tannoy's have, but something to keep in mind is that AlNiCo magnets get weaker with age. Also, they can loose much of their magnetism if they are dropped or other impact occurs. Having them re-magnetised can be tricky, depending on their design. Most of the vintage AlNiCo drivers I've had are fine, but I've had a couple that had the magnet much weaker than it should be.
Dave
Re: Vintage speakers vs. modern [message #15163 is a reply to message #15161] Wed, 11 January 2006 19:16 Go to previous messageGo to next message
Perfect; they have a pretty flat impedance curve that stays above 5ohms most of the time; so a tube amp is perfect for them. Which amp did you have in mind?
Not the slightest chance [message #15193 is a reply to message #15159] Tue, 31 January 2006 15:31 Go to previous message
egeddes is currently offline  egeddes
There is no way that the speakers will be as good as new. All materials change with time and any change takes the speaker further away from its intent.
Previous Topic: Dipoles and directivity
Next Topic: And now for something completely different ......
Current Time: Fri Nov 13 08:22:34 CST 2026
