Home » Audio » Speaker » Internal Damping Material
Internal Damping Material [message #14937] Sun, 17 April 2005 09:18 Go to next message
I was wondering if anyone has compared the materials that are commonly used for internal damping in diy enclosures? Specifically, has anyone done comparisons of eggcrate foam, R11 or R13 home insulation, and Armstrong #420 5/8" rigid fiberglass.
My own superficial impression (without doing any valid measured comparisons) is that the eggcrate foam doesn't absorb very much sound, the home insulation seems to do a good job but is too thick for some appliciations, especially in small volume enclosures, and the 5/8" rigid fiberglass seems to be the most effective. I have used all three, but when I have completed an enclosure I'm not inclined to remove and reinstall damping material (especially the rigid Armstrong ceiling stuff) through the driver holes, so I haven't done any valid comparisons.
Wayne, Bob, others, what do you think?
Re: Internal Damping Material [message #14938 is a reply to message #14937] Sun, 17 April 2005 13:07 Go to previous messageGo to next message
I also think that position is important. If you take a 1" thick absorbent material and place it on the wall, it will act differently than if you place it a few inches out away from the wall. It will do a much better job of absorbing midrange when spaced further out. So the thicker insulation acts differently by virtue of its position by way of its thickness, and that may be as important or more so than its absorbsion coefficient.
Re: Internal Damping Material [message #14939 is a reply to message #14937] Mon, 18 April 2005 12:41 Go to previous messageGo to next message
I haven't had the exposure to different speakers like Wayne or Bob, but the of the four sets of cabinets I've built so far, I haven't had any problems with eggcrate not absorbing. Of course, my only method for testing is sticking my ears against the port to listen for any midrange. I've been lucky to date.
gar.
Re: Internal Damping Material [message #14940 is a reply to message #14937] Mon, 18 April 2005 20:47 Go to previous messageGo to next message
I line all of my boxes with Armstrong #420. It is much easier to work with than batting or loose fill. I find that a single layer on the four walls eat anything above 500 Hz. It cuts with a knife, holds its shape and with a little 3M #77, it stays put. Of course, I work with pipes and BR's. Stuffing a sealed box is a whole 'nother thing.
Bob
Re: Internal Damping Material [message #14941 is a reply to message #14940] Tue, 19 April 2005 07:24 Go to previous messageGo to next message
Bob,
I'm not familiar with what Armstrong #420 is. Can you please elaborate or provide link for more detail.
thanks,
gar.
Re: Internal Damping Material [message #14942 is a reply to message #14941] Tue, 19 April 2005 16:52 Go to previous messageGo to next message
It's compressed fiberglass ceiling tiles with a plastic surface used to make a suspended ceiling. Very good acoustic properties, and to use is inside a speaker enclosure you peel off the flexible plastic surface. But it's really nasty to work with.
Re: Internal Damping Material [message #14943 is a reply to message #14937] Thu, 21 April 2005 09:23 Go to previous message
theNoid is currently offline  theNoid
I have been building speakers and subwoofers for many years. Combined total well over 100 enclosures easily. For sealed boxes I always use the standard "fluffed" polyfill from Wal-Mart or other craft stores. For ported boxes I have always used egg-crate foam or polyfill batting glued to the inside walls. As mentioned, of the many speakers I have built, I have never had a problem nor a complaint about either. Cheap, easy, and it works.
Noidster
Previous Topic: manipulation of horn calculation
Next Topic: any box suggestion for coral beta 6"
Current Time: Fri Nov 13 05:47:34 CST 2026
