Home » Audio » Speaker » Internal Damping Material
Internal Damping Material [message #14937] Sun, 17 April 2005 09:18 Go to previous message
I was wondering if anyone has compared the materials that are commonly used for internal damping in diy enclosures? Specifically, has anyone done comparisons of eggcrate foam, R11 or R13 home insulation, and Armstrong #420 5/8" rigid fiberglass.
My own superficial impression (without doing any valid measured comparisons) is that the eggcrate foam doesn't absorb very much sound, the home insulation seems to do a good job but is too thick for some appliciations, especially in small volume enclosures, and the 5/8" rigid fiberglass seems to be the most effective. I have used all three, but when I have completed an enclosure I'm not inclined to remove and reinstall damping material (especially the rigid Armstrong ceiling stuff) through the driver holes, so I haven't done any valid comparisons.
Wayne, Bob, others, what do you think?
Previous Topic: manipulation of horn calculation
Next Topic: any box suggestion for coral beta 6"
Current Time: Sun Oct 18 18:21:26 CDT 2026
