Home » Audio » Speaker » speaker ohms
Re: Details on 16 ohms please [message #14700 is a reply to message #14699] Sun, 05 September 2004 07:50 Go to previous messageGo to previous message
Sure- a JBL 2426. This is available in both 8 and 16 ohm versions, and you usually see 16 used. Since this has 110 dB sensitivity it's only logical to use a 16 ohm coil to better match it with a 100dB woofer section. Another advantage here is that as you raise the impedance you lower the crossover point, or, conversely, lower the size of the crossover components to maintain the same crossover frequency, which means that for a 16 ohm driver versus 8 ohm the crossover component sizes are halved, which saves serious money in the case of high-power high order crossovers.
Previous Topic: Doppler distortion
Next Topic: Cats vs Speakers
Current Time: Thu Nov 05 06:39:02 CST 2026
