Home » Audio » Speaker » Vifa two way
Re: line array [Re: Vifa two way] [message #14630 is a reply to message #14629] Sat, 12 June 2004 13:48 Go to previous messageGo to previous message
With 99dB sensitivity it can be driven by anything, though to keep the driver count down (at 8 woofers instead of 16) it does have a 5 ohm impedance. Of course that's with 8 ohm drivers; using 16s or 4s you can go 8 drivers for 8 ohms. I wasn't concerned about the impedance as with that sensitivity it won't be drawing a lot of current.
You're correct about the configuration, though the exact details I can't reveal until publication.
The problem with PVC is that if left unstuffed it's a very resonant speaker, a one-note if you will, and even stuffed isn't as good as a tapered line. Ten feet gives quarter-wave tuning at 28 Hz, and that's probably well below the Fs of a driver small enough to fit it, so a mis-match there.
Two drivers is the way you mention is feasible, with tuning perhaps a third-octave apart to smooth things out.
Previous Topic: Eminence LA6
Next Topic: cone patching or repairs
Current Time: Thu Nov 05 19:31:23 CST 2026
