Home » Audio » Speaker » Can't reproduce a square wave
Off topic - Air compression linearity [message #14572 is a reply to message #14541] Thu, 01 April 2004 05:16 Go to previous message
Hey, Tom - What do you make of this? Do you have any references for research data that shows the onset of air compression non-linearity?
I assumed it must be somewhere between 1.5 and 2 atmospheres for a sinusoidal piston motion that creates alternating compression and rarefaction. I also would guess that plenums, vents and other resonant chambers would have certain frequencies where they were more sensitive due to resonant conditions. At frequencies where a vent or plenum is resonanting, we'll get a ram-charge effect where critical pressures are reached at lower piston excursions.
But putting resonance aside, I wonder where air rarefaction/compression starts becoming noticably asymmetrical, causing non-linear distortion. Kinda thought you might know a reference or two.
Previous Topic: Effects of a low pass notch filter on BR versus TL: speculations
Next Topic: Re: Can a notch filter improve phase lag?
Current Time: Mon Oct 05 11:14:47 CDT 2026
