Home » Audio » Speaker » Suppose you had a really big pair...
Suppose you had a really big pair... [message #14497] Sun, 08 February 2004 03:10 Go to next message
Like two Altec 3182 woofers (18 inch, Fs=18, Qts=0.4, EBP=45)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3702903562&category=47094&sspagename=STRK%3AMEBWN%3AIT&rd=1
In a closed box approximately 7 ft^3, they're F3 at 40Hz, -6dB at 30Hz
Vented at 30 ft^3, they're F3 at 20Hz
Now 30ft^3 does approach difficult to accomodate in a domestic situation (to put it mildly), but would it be worth it vs. 6dB of EQ in 7 ft^3 to flatten the response to 30Hz (probably not even that much boost with room augmentation)?
Re: you have entered the sickness Zone [message #14498 is a reply to message #14497] Sun, 08 February 2004 10:30 Go to previous messageGo to next message
Just buy an EQ :)
you'r wife will love you for it
hahaha
Re: the sickness Zone - ooops! it shows? [message #14499 is a reply to message #14498] Sun, 08 February 2004 15:23 Go to previous messageGo to next message
Not thinking too clearly at 2 AM.
Fooled with a tape measure for about 5 minutes. No matter what the aspect ratio 30 ft^3 sized to fit through the doorway from the garage into the house is pretty unmanageable.
It ought to have occured to me that it would be approximately the same size as the 26 ft^3 refrigerator in the kitchen - I don't see two of those in the living room.
Looks like it's going to be sealed. The weird thing is my wife is an absolute saint - she wouldn't care what I did. The bad part is that I have to exercise some sort of self control in these matters, not exactly my long suit .
Re: the sickness Zone - ooops! it shows? [message #14500 is a reply to message #14499] Sun, 08 February 2004 15:55 Go to previous messageGo to next message
I hear ya, My wife is a saint too. Problem is two martini's and self control becomes extinct
[message #14509 is a reply to message #14499] Sun, 15 February 2004 15:14 Go to previous messageGo to next message
30cubes each?
900L ?
i could design a corner basshorn using the lab12 that does 25hz flattish with ~103db efficiency and less than that volume!
did u buy them?
its hardly worth it,what about raising the Qts artifically and using them for dipoles or IB ! got an attic?
Cheers!
Re: [message #14513 is a reply to message #14509] Tue, 17 February 2004 03:45 Go to previous messageGo to next message
This driver doesn't need 900L though unless you want an F3 below 20Hz on its own without room gain.
400L/16Hz tuned gives ~28Hz anchoic F3 and ~22Hz F6 with this driver (Altec 3182).
Its Qts is 0.40
Re: Suppose you had a really big pair... [message #14556 is a reply to message #14497] Sun, 21 March 2004 06:16 Go to previous message
HI,
If you are using them for a sub, think about and active crossover, and biamping them in a much smaller enclosure. I have a pair of EV force 15s that are similar to yours, and if i ever get arounfd to using them, that is what i will do.
-akhilesh
Previous Topic: DUO screech
Next Topic: What is the throat dimension of the Altec A7 horn?
Current Time: Mon Nov 30 12:17:38 CST 2026
