Home » Audio » Source » DSP-Rack
DSP-Rack [message #14452] Wed, 24 October 2007 12:50 Go to next message
micheal is currently offline  micheal
DSPRack is a real-time effect-processing software, running on Windows , which can process direct audio source thru native (DSP’s) or VST effects.
It also provides a built-in loop processor that will play wav files in the background, while you play your instrument(with pitch shift and time stretch).
It requires an ASIO enabled input/ouput device with a fairly high quality device driver in order to operate with as small a latency as possible (delay between input and output).
Re: DSP-Rack [message #14453 is a reply to message #14452] Wed, 24 October 2007 15:48 Go to previous message
Is this for hifi use or prosound?
Previous Topic: Good night at the auction
Next Topic: Setting up a turn table
Current Time: Fri Oct 16 11:13:09 CDT 2026
