Home » Audio » Source » Which studio is right for you
Which studio is right for you [message #14448] Fri, 19 October 2007 09:45
Gilipsie is currently offline  Gilipsie
It's important to know your goal when it comes to what kind of studio you wish to build. Is the studio meant to record the local g bands or will it be used only to record a weekly podcast shows or maybe just for songwriting purposes? The amount of money to be invested in the gear and software is a function of the purpose of the home studio, how much effort you are willing to put in to learn everything, and the size of the budget.
Some things are common to all studios whether they are as big as Abbey Road or as small as a typical bedroom studio.
The Sequencer - This is the device which records, visualizes and plays back the music that is recorded in the form of audio or midi data. Some popular sequencers are Logic Pro, Pro Tools, and Cubase.
The Sound Card - The sound card or the audio interface connects the sound source (microphone, guitar, keyboard) to your computer. It converts the audio from analog to digital and back from digital to analog. An audio interface provides different input and output options and is often equipped with one or more pre-amps to enhance the audio signal.
The Instruments - Apart from the usual instruments like guitar, bass or ukulele, the most common instrument is the midi controller. A midi controller is nothing but a keyboard. The difference is that it doesn’t produce any sound of its own. It simply tells the sequencer how and when to play the sound that the user has loaded up in the sequencer. For e.g. you can load up a piano plug-in in your sequencer and play it with the midi keyboard.
The Plug-ins - All home studio's need plug-ins. From adding reverb to playing piano sounds, all work can be done with the help of plug-ins. The time when you needed individual players for different instruments is gone. Today a melody line can be played and auditioned using different instruments at the click of a mouse. These plug-ins are commonly referred to as soft-synths and are loaded up and triggered from within the sequencer.
The Computer - It goes without saying that without a workstation the digital studio wouldn’t be complete. The MAC or the PC debate. MACs are stable, but offer no expansion opportunities (except the memory). PCs are easily expandable and cheap, but aren’t as powerful as the MACs. The basic requirement for the computer is a CD/DVD burner, multiple USB/Firewire ports, speakers and lots and lots of free hard drive space and memory. All in all the computer should fit the requirements of your chosen sequencer
Previous Topic: Ion Audio
Next Topic: Sound card help
Current Time: Fri Oct 16 17:44:01 CDT 2026
