Home » Audio » Source » Mic Preamp
Mic Preamp [message #14412] Mon, 10 September 2007 21:35 Go to next message
Crystal is currently offline  Crystal
Ok so I'm thinking about putting a studio together and right now I'm looking into a microphone preamp. The reason why I'm thinking I need this is because if I were to plug my microphone into my computer's soundcard or even my mixer, the quality would be horrible.Is it mandatory to get a preamp for your mic? I don't really want to buy a big bulky one because my home studio is going to be small.
Re: Mic Preamp [message #14413 is a reply to message #14412] Tue, 11 September 2007 08:08 Go to previous messageGo to next message
Here's a microphone preamp, if you don't mind DIY:
Re: Mic Preamp [message #14414 is a reply to message #14413] Tue, 11 September 2007 12:25 Go to previous messageGo to next message
So how does the preamp work with the whole battery thing? I mean wouldn't you want to be able to plug in your preamp instead of sticking batteries in it?
Re: Mic Preamp [message #14418 is a reply to message #14414] Wed, 12 September 2007 08:55 Go to previous messageGo to next message
You can build a power supply, sure. There is no requirement that the +3V source be batteries. Batteries are a very noise-free power source though, and the current draw is small so the batteries last a long time.
Re: Mic Preamp [message #14426 is a reply to message #14414] Thu, 13 September 2007 12:57 Go to previous messageGo to next message
Gilipsie is currently offline  Gilipsie
Since the draw of energy from the batteries is small, you wouldn't actually be spending tons of money on them all the time. But I honestly prefer to plug my pre amp in.
Re: Mic Preamp [message #14433 is a reply to message #14418] Mon, 17 September 2007 12:46 Go to previous messageGo to next message
willyable is currently offline  willyable
So are you saying that having a power supply that plugs in isn't noise free?
Re: Mic Preamp [message #14439 is a reply to message #14433] Mon, 17 September 2007 17:58 Go to previous messageGo to next message
An AC power supply rectifies DC power from AC, so there is necessarily a filter. You'll have rectifier switcing artifacts and low frequency AC noise to deal with. A battery does not have these issues.
A battery has higher internal source impedance and has to be recharged or replaced, so those are the downsides to a battery. But it is pretty noise free and can be an attractive option, especially in a circuit like this that needs to be noise free and that has very low curent draw.
Re: Mic Preamp [message #14441 is a reply to message #14439] Tue, 25 September 2007 12:17 Go to previous messageGo to next message
So you think Wayne that you should go with a mic preamp that uses batteries instead of plugging in?
Re: Mic Preamp [message #14444 is a reply to message #14441] Wed, 26 September 2007 12:24 Go to previous message
sacback is currently offline  sacback
I use a pre mic amp that uses batteries. I use to have a power supply that plugged in but in all acutality, I feel as if I get much more quality from using batteries.
Previous Topic: Cassettes No Longer Being Stocked?
Next Topic: Turntable help
Current Time: Fri Nov 13 05:20:28 CST 2026
