Home » Audio » Source » digital to digital converter ?
digital to digital converter ? [message #14184] Tue, 18 January 2005 11:11 Go to next message
Anyone know if there is a product that decodes DTS and Dolby Digital and then routes it to multiple digital outputs(S/PDIF or AES/EBU)? I want more control before the analog stage.
Thomas
How 'bout a splitter? [message #14185 is a reply to message #14184] Tue, 25 January 2005 21:43 Go to previous message
I don't know if this will work for you, but it's a possible simple and inexpensive solution. If you have optical I/O onboard, you might just go with a splitter like this:
If you only need 2 outputs, there are tons of 'em on the market for five or ten bucks. You can probably find them locally or shop around, if not, here are a few for less than $10.00 on Amazon.com:
Previous Topic: turntable troubles...
Next Topic: need some help
Current Time: Thu Nov 12 21:47:28 CST 2026
