Home » Audio » General » Tripp Lite go no go
Re: Tripp Lite go no go [message #1412 is a reply to message #1409] Fri, 01 April 2005 05:41 Go to previous messageGo to previous message
Check the waveshape coming out when the batteries are running. The expensive converters make nice clean power but some inexpensive converters put out a pretty grungy signal.
In fact, I ran one when I was overseas and connected a barrier strip with built-in surge protection. The converter in the UPS generated such high spikes, the protection MOVs in the barrier strip tried to clamp them and shorted out. I removed the shorted MOVs and converted the barrier strip into an unprotected unit. The UPS had been damaged but a second one worked fine, so I was able to run equipment with it even when power failed.
The point of all this is that inexpensive UPS units make a signal that is so marginal it actually damages equipment with surge protectors built in. So be careful and check the signal before using it with anything delicate or expensive.
Previous Topic: Great Plains Audiofest - INFO
Next Topic: $125,000 Audio Note speakers at GPAF?
Current Time: Fri Nov 20 00:42:23 CST 2026
