Home » Audio » Source » ART DI/O mods?
Re: ART DI/O mods? [message #14054 is a reply to message #14051] Thu, 18 December 2003 12:35 Go to previous messageGo to next message
brianjones is currently offline  brianjones
I am running the cdp (Adcom GCD700 changer with remote volume control it has a digital out) ) in variable mode now with the Harmonic Recovery System between the power amp. Any guess if the Art DI/O improve the sonics of the Adcom w/ the H.R.S. ?
Re: What's the latest on power supplies? [message #14055 is a reply to message #14053] Thu, 18 December 2003 13:11 Go to previous messageGo to next message
Wayne1 is currently offline  Wayne1
Jim,
Look around in Mouser or Digikey for a good E-core transformer, 9-10 VAC at 5 amps or better. Stick it in a good steel case and use very good cable and connectors from the AC outlet and to the DI/O connectors.
Make sure you've changed out the 5 volt regulator inside the DI/O. The stock one does not regulate well at all.
Re: ART DI/O mods? [message #14056 is a reply to message #14054] Thu, 18 December 2003 13:12 Go to previous messageGo to next message
The better the equipment the less the gain. It will give it a warmer sound and you might like it. Make sure the digital output on your CD is variable if your counting on that for attenuation.
Bill
Thanks! Will do (nt) [message #14057 is a reply to message #14055] Thu, 18 December 2003 14:39 Go to previous messageGo to next message
Jim D. is currently offline  Jim D.
Re: ART DI/O mods FAQ [message #14058 is a reply to message #14052] Fri, 19 December 2003 20:15 Go to previous messageGo to next message
Thanks for the link. I've been looking it over and I think I'll try some mods and see what happens.
Bill
Re: ART DI/O mods FAQ [message #14059 is a reply to message #14058] Fri, 19 December 2003 20:30 Go to previous messageGo to next message
Bill,
You are welcome. If you have any questions about any of the mods, drop me a line. I have modded several hundred and should be able to help you if you run into any problems.
Happy Holidays!
Wayne Waananen
Re: ART DI/O mods? [message #14075 is a reply to message #14044] Sun, 08 February 2004 12:04 Go to previous message
HI,
The tube part of this converter is only A to D. The D2A actually runs better without the tube, sicne there is less heat in the case.
Boulder cables does some good mods.
I have no idea how good the output stage is, but some people swear by the modded dac. I decided to go a different route (much older high end)
Previous Topic: Marantz TT320 turntable info needed
Next Topic: Denon DP-25F belt fell off, help!
Current Time: Fri Nov 13 05:03:04 CST 2026
