Home » Audio » Source » GX-95 Qs
Dolby variants [message #14005 is a reply to message #14004] Thu, 06 March 2008 16:13 Go to previous messageGo to previous message
I would try different brands of tape and see what works best. In my experience, both Dolby C and Dolby HX were very tape sensitive. If you have a bias adjustment, that can help but since HX plays with bias levels, I think you'll still be media-sensitive.
Dolby B is much less sensitive to media. It works pretty well on all good quality tapes, and even on cheap ferrite tapes, I never noticed irritating artifacts. Worst thing is a loss of the top octave when decoded, when a cheap tape doesn't "hold" the increased treble from the encoding filter. You can always turn the decoder off, which has the effect of boosting the top octave. Of course, with the decoder off, you won't have noise reduction but instead will have treble boost. The increase it gives to the top octave is usually welcome on those cheap tapes anyway.
This isn't the case with Dolby C or HX in my experience. Some tapes just can't be made to sound good with them. You can't expect a tape encoded with Dolby C to sound good if the decoder is off, so cheap tapes really couldn't be used. When they don't retain the increased HF from encoding, you can't just turn off the decoder so the tape sounds bad either way.
Previous Topic: Technics 1200MK2 european in the US help?
Next Topic: Sony CD won't play in older Aiwa stereo
Current Time: Thu Nov 19 07:21:20 CST 2026
