Home » Audio » Source » GX-95 Qs
GX-95 Qs [message #14004] Thu, 06 March 2008 05:18 Go to previous message
fax is currently offline  fax
When I record music using GX-95 on normal type 1 tape, using HXPRO + Dobly
C, it sounds as if you play a normal tape recorded without any Dolby with
Dolby C turned on, with the exception that high frequency is good, sounds
like it tries to cancel the noise, and a bit too much, so like someone
"breathing" air in and out, if you see what I mean.
Anyone's GX-95 have this effect? What's the difference in Dolby C
perfoemance with GX-95 and GX-95MKII if you have both machines.
Also someone gave me a GX-75MKII tape guide replacement part,
do you know it is the same part used in GX-95, because the one I got is
almost perfect if it had its broken tape guide replaced.
Previous Topic: Technics 1200MK2 european in the US help?
Next Topic: Sony CD won't play in older Aiwa stereo
Current Time: Thu Nov 19 07:02:39 CST 2026
