Home » Audio » Source » Technics SL BD22
Technics SL BD22 [message #13743] Mon, 09 March 2009 16:45 Go to next message
Andy is currently offline  Andy
Hi I've just bought an SL BD22 turntable which I've connected to my Technics amplifier. The first turntable I had connected via wires to the turntable and was fine. However the SL BD22 has a ground wire connection which it says to connect to the GND connection on my amp. I've done all this and connected the red and white leads, but the turntable will not turn and the stroboscope will not light up. Any ideas on solving this problem? PS I've checked plugs and belt on turntable
Re: Technics SL BD22 [message #13744 is a reply to message #13743] Tue, 10 March 2009 16:32 Go to previous messageGo to next message
Sorry for the silly question, but did you plug it in to main power? The turntable requires power, not just a connection to the amp.
Re: Technics SL BD22 [message #13745 is a reply to message #13744] Tue, 10 March 2009 17:58 Go to previous messageGo to next message
andyhig is currently offline  andyhig
Hi, yeh everthing plugged in where it should be.
Re: Technics SL BD22 [message #13746 is a reply to message #13745] Thu, 12 March 2009 17:49 Go to previous message
Sounds like it might have blown the fuse.
Are you sure it's wired for the right mains voltage level? Check that, and the fuse.
Previous Topic: sparton 78 rpm
Next Topic: More Audio-Technica 440MLA, a review, kinda
Current Time: Thu Nov 05 15:41:43 CST 2026
