Home » Audio » Source » CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING
CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING [message #13682] Tue, 03 June 2008 06:38 Go to next message
BETTY is currently offline  BETTY
I'VE HAD MY RECORD PLAYER FOR 5 MONTHS NOW, I USE IT DAILY, WHEN I WENT TO LISTEN TO A RECORD EARLIER IT WOULD NOT WORK. THE MOTOR IS NOT MOVING, THERE IS NO SOUND WHEN I RUB THE NEEDLE, THE BELT IS NOT LOOSE OR BROKEN, WHAT COULD BE THE PROBLEM? IT WAS WORKING FINE YESTERDAY..
Re: CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING [message #13683 is a reply to message #13682] Tue, 03 June 2008 16:18 Go to previous messageGo to next message
Renois is currently offline  Renois
I think your motor or switch must be bad. Is it covered by warrantee?
Best,
Renois
Re: CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING [message #13685 is a reply to message #13683] Tue, 03 June 2008 19:26 Go to previous messageGo to next message
I purchased it brand new on Ebay, No warranty.
Re: CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING [message #61657 is a reply to message #13682] Fri, 01 January 2010 21:07 Go to previous messageGo to next message
majick47 is currently offline  majick47
It's a Crosley! Time to get a real turntable.
Re: CROSLEY KEEPSAKE TURNTABLE STOPPED SPINNING [message #61855 is a reply to message #13682] Mon, 15 February 2010 08:19 Go to previous message
AudioAJ is currently offline  AudioAJ
Unfortunately you're probably out the money you spent. Crosley doesn't have the best reputation. The biggest complaint I've heard about them is that their playing speed is inconsistent. Time to get a new turntable. Sorry
Previous Topic: Panasonic rd9090
Next Topic: Pioneer RT-909
Current Time: Sat Oct 24 23:51:23 CDT 2026
