Home » Audio » Source » Turntable buzz
Turntable buzz [message #13632] Tue, 22 January 2008 11:16 Go to previous message
Chris E. is currently offline  Chris E.
Hello everyone,
I recently bought a used Technics SL-1200 MK2. Unfortunately, it makes a slight(!) buzzing noise when I connect the needle cartridge to the tone arm. The cartridge is not the problem as it works fine on my SL-1210. Also, it's not a loud or harsh buzzing noise like the one you get when you don't ground the turntable properly. Only an audible, but quite annoying one.
Does somebody know what could cause this? Thanks for your replies!
- Christopher
Previous Topic: HELP! Sony ps q3 needs repair
Next Topic: Which should I keep?
Current Time: Mon Nov 23 01:38:41 CST 2026
