Home » Audio » Source » total newbie pls help w/ setting up Pro-Ject Debut III Phono SB???
total newbie pls help w/ setting up Pro-Ject Debut III Phono SB??? [message #13623] Sun, 06 January 2008 14:23 Go to next message
Besidethesea is currently offline  Besidethesea
Hi there,
am a total newbie to turntables. have used them before but never tried to set one up. bought myself one of these
http://www.project-audio.com/main.php?prod=debutphsb&cat=turntables&lang=en
and have tried to follow the instructions to best of my ability but the needle won't sit on the record, the tonearm just drifts away to the right.
There is a weight which goes on the end of the tonearm. it said attach this weight then twist to adjust it until the tonearm hovers balanced. which i did. it said then return to the clip then hold the weight, and turn the dial attached to the weight until the zero lines up with the pin in the tonearm that the antiskating weight loops onto. which i did. then it said NOT holding the weight, turn the dial to 17.5, the appropriate setting for the cartridge it came with. which i did.
it appears that the anti-skating weight is pulling the tonearm away to the right, but i put it on the setting on the pin (second ridge) as per the instructions.
in short, i have no idea what i am doing or what i have done wrong.
help?
thanks in advance,
besidethesea.
Re: total newbie pls help w/ setting up Pro-Ject Debut III Phono SB??? [message #13625 is a reply to message #13623] Sun, 06 January 2008 20:45 Go to previous message
real_one is currently offline  real_one
Nice little table. Look through the posts here:
Previous Topic: The Doctor Is In
Next Topic: Sony TC-650
Current Time: Mon Oct 19 08:16:30 CDT 2026
