Home » Audio » Source » Technics SL-220 45rpms
Technics SL-220 45rpms [message #13550] Thu, 18 October 2007 00:35 Go to next message
Y. Kang is currently offline  Y. Kang
Hey guys another question on my second-hand Technics SL-220..
I got the pre-amp and now it works great but I"m having trouble when adjusting the rpms.. 33 rpms runs fine but when I adjust it to 45 it won't play. If i move the slider just right before it 'clicks' into '45rpm' it'll run but I can tell that it's slightly off-speed -- any suggestions?? Or am I just going to listen to 33rpms??
Thanks in advance,
Y. Kang
Re: Technics SL-220 45rpms [message #13552 is a reply to message #13550] Thu, 18 October 2007 08:21 Go to previous messageGo to next message
Sounds like it might be time to take it to the shop.
Re: Technics SL-220 45rpms [message #13553 is a reply to message #13552] Thu, 18 October 2007 10:59 Go to previous message
Thanks for all the help Wayne -- it turned out that the pitch adjusters are still functioning so I"ve just calibrated it by sound
Previous Topic: Gemini tt02 problem
Next Topic: Ion Audio
Current Time: Fri Oct 16 21:59:12 CDT 2026
