Home » Audio » Source » Gemini tt02 problem
Gemini tt02 problem [message #13542] Tue, 16 October 2007 14:19 Go to next message
Jamie is currently offline  Jamie
I have just bought a pair of direct drive Gemini tt02s off ebay with a behringer DJX700 and ive been having a problem with one of the turntables. It plays the song faster than it should do but when I put my hand on the vinyl to slow it down until it sounds right so I take my hand off and it carries on playing the vinyl right. Then when I change the vinyl and drop it in the same thing happens again. WHAT IS GOING ON!?!?!?!?!? its like i have to correct the turntable and then it stops working when I change the vinyl!
Re: Gemini tt02 problem [message #13547 is a reply to message #13542] Wed, 17 October 2007 09:02 Go to previous messageGo to next message
It has a pitch control. Have you tried adjusting it?
Re: Gemini tt02 problem [message #13548 is a reply to message #13547] Wed, 17 October 2007 12:10 Go to previous messageGo to next message
yes I have. The pitch changes even if I leave the pitch alone. I have used the cut out time circles in the manual on them and it definately speeds up alot if you push the vinyl forward and it won't go back to the original unless you slow it down with your hand. It is a very weird problem and I really want to get to the bottom of it
Re: Gemini tt02 problem [message #13551 is a reply to message #13548] Thu, 18 October 2007 08:20 Go to previous message
Sounds like the servo system is shot. I think you'll need to take it into the shop.
Previous Topic: Technics SL-220 Very low volume output!
Next Topic: Technics SL-220 45rpms
Current Time: Fri Oct 16 21:55:52 CDT 2026
