Home » Audio » Source » Elac Miracord 50 H TURNTABLE CARTRIDGE
Elac Miracord 50 H TURNTABLE CARTRIDGE [message #13448] Mon, 23 July 2007 16:13 Go to next message
M.B. Hanna is currently offline  M.B. Hanna
Please help me as I have been unable to replace the cartridge.
Cannot find a business in Albuquerque, NM that sells the cartridges. Purchased in 1969 in Germany.
Re: Elac Miracord 50 H TURNTABLE CARTRIDGE [message #13458 is a reply to message #13448] Wed, 25 July 2007 16:07 Go to previous message
Listens2tubes is currently offline  Listens2tubes
Hi,
I have a Elac Miracord 650 with a Elac STS 344 cartridge. It is a tall cart but uses standard 1/2" mounting. The head shell allows for cartridge alignment, if the arm allows for VTA setting then you can use any cartridge you desire. I can recommend the Shure M97xE as it has a very nuetral sound and can be found at http://www.amazon.com/Shure-M97xE-High-Performance-Magnetic-Cartridge/dp/B00006I5SB Enjoy!
Previous Topic: Vinyl revival
Next Topic: digital tables
Current Time: Thu Nov 05 03:34:01 CST 2026
