Home » Audio » Source » pitch control problem
Re: pitch control problem [message #13435 is a reply to message #13434] Wed, 18 July 2007 14:49 Go to previous messageGo to previous message
If your turntable is servo controlled, then the problem is likely within the PLL control circuit. Slow speeds are sometimes the result of a simple mechanical problem but fast speed usually means the servo circuit is bad. You may have to replace the servo circuit to see if that fixes it.
Previous Topic: Good vinyl score
Next Topic: Warped sounding: not the album, platter or belt...what is it??
Current Time: Thu Nov 05 20:50:53 CST 2026
