Home » Audio » Source » new here: just bought a Technics SL-220
Re: new here: just bought a Technics SL-220 [message #13414 is a reply to message #13410] Tue, 26 June 2007 16:35 Go to previous message
Dominic is currently offline  Dominic
First lock the arm, remove the headpiece and carefully place the TT upsidedown in your lap resting on your legs. Treat it like a baby. Make sure the arm is not under undue pressure. Remove the cover underneath and study the mechanism, carefully moving the arm through its play cycle. Something is causing it to go into the return cycle to early. There is usually a trip lever attached to the moving tone arm that catches a “dog” on the platter. This then initiates the return cycle. I have looked at a lot of TTs and often a little machine oil may solve the problem. But first give it a good hard look. Try to figure out what is tripping the “dog” early.
Previous Topic: RCA Victor Orthophonic High Fidelity 7-HF-5
Next Topic: BSR turntable
Current Time: Thu Nov 05 20:19:36 CST 2026
