Home » Audio » Source » Denon DP-300F
Denon DP-300F [message #13365] Wed, 25 April 2007 10:32 Go to next message
Michael M is currently offline  Michael M
I got this Denon a few months ago, and more recently its begun sounding a bit off. Certain frequencies - basically higher treble - sound scratchy and muddled, almost as though my stylus is dusty (but its not). This happens with virtually all of my records, independent of how clean they are. I've called Denon and they don't seem to have much of an answer. Thoughts?
Re: Denon DP-300F [message #13367 is a reply to message #13365] Thu, 26 April 2007 02:00 Go to previous messageGo to next message
Have you looked at the stylus under magnification? Could be caked with gunk that can't be brushed off?
Try brushing with denatured alcohol. Be careful not to get any on the cantilever where it meets the body, especially if it's a Grado. And/or work at it with a Magic Eraser.
Re: Denon DP-300F [message #13368 is a reply to message #13367] Thu, 26 April 2007 18:57 Go to previous message
It seems unlikely that it's specifically the stylus, just because I've actually tried another stylus and the problem continued. is it possible the wiring/other connections between the stylus and tonearm are damaged?
Previous Topic: All done now
Next Topic: How to replace a platter?
Current Time: Fri Nov 06 21:33:50 CST 2026
