Home » Audio » Source » Tonearm Balancing Problems
Re: Tonearm Balancing Problems [message #13341 is a reply to message #13340] Sat, 07 April 2007 01:49 Go to previous messageGo to previous message
Coda1108 is currently offline  Coda1108
As long as you've calibrated it to the least amount of pressure without having the tonearm swing back to its resting position, you should be all right. The wear and tear on your vinyl will also depend on the age of your records. Newer vinyl will handle the wear and tear just fine. If you're playing old '78s, you need to be careful no matter what.
Previous Topic: Best Turntable Model? BSR, Dual, NAD...
Next Topic: Garrard 210
Current Time: Fri Nov 06 07:54:25 CST 2026
