Home » Audio » Source » overhang
overhang [message #13306] Wed, 07 March 2007 00:07 Go to next message
kpl017 is currently offline  kpl017
Is it possible to adjust for correct cartridge alignment at the 2 null points with different overhang distances? Assuming, of course, the same arm and cartridge on the same table. Or, is there only 1 overhang that goes with successfully adjusting to the null points?
Guess I'm also trying to figure out whether it is possible to determine the correct overhang for any arm with no known overhang specs. Any info or opinion much appreciated.
Re: overhang [message #13310 is a reply to message #13306] Wed, 07 March 2007 13:27 Go to previous messageGo to next message
I'm not sure if that specific question is answered in the documents below, but I think it's probably worth looking.
Re: overhang [message #13312 is a reply to message #13306] Thu, 08 March 2007 17:51 Go to previous messageGo to next message
dvautier is currently offline  dvautier
I would say yes at least for midrange and high quality TTs. On each of the headpieces I have there is a slot that is about ΒΌ inch. I have never bothered to measure overhang and I usually set the cartridge at about 2/3rds of the way down the slot.
Re: overhang [message #13321 is a reply to message #13312] Tue, 13 March 2007 21:59 Go to previous messageGo to next message
Thank you, dvautier, for your thoughts on the subject.
Re: overhang [message #13322 is a reply to message #13310] Tue, 13 March 2007 22:01 Go to previous message
Thanks, Wayne, for the reference. They don't seem to answer my query.
Previous Topic: SYSTEMDEK 11
Next Topic: JVC L-A55 auto-return
Current Time: Thu Nov 05 23:01:50 CST 2026
