Home » Audio » Source » Interesting discovery: SME 3009 series 2 Improved
Interesting discovery: SME 3009 series 2 Improved [message #13273] Wed, 07 February 2007 18:14
While I was doing all that heavy lifting on the cartridge I found that there is no set screw holding the spring and plastic bit that maintains pressure against the 'way rod' to keep the 'rider weight' from slipping. Something on the plastic bit must have worn off and they slipped out.
Not wanting to trust the 'rider weight' to stay put by itself I tapped the hole with a 6-32 tap and installed a stainless steel set screw. The hole is of a size that it's just what you'd drill for a 6-32.
Previous Topic: Sony LX250H turntable
Next Topic: Cartridge adjustment
Current Time: Thu Nov 05 19:28:39 CST 2026
